Incorrect usage count?
active8
I think my broadband usage is being miscalculated as I have an automated downloading operation setup to download btween midnight and 8am and I have done light web browsing today however the usage history for today says I have used 2.74gb - this makes no sense! I am nearing my monthly usage allowance and Im sure something is not right.
I dont want to be capped to a very low speed for 5 days if my usage is being counted incorrectly.
Thanks!
acarneiro
Re: Incorrect usage count?
I'm sorry if this sounds silly, but have you confirmed that your software has in fact obeyed your scheduling?
Have you confirmed the scheduling is set between 00:00 and 08:00 (I set mine to 00:05 and 07:55 just to be safe)
Have you checked the clock on the machine, to make sure the scheduling is being applied correctly?
Plusnet Staff
Plusnet Staff
Fixes: 159
Looking at your hourly usage (I can provide that to you if you like?), most of the peak usage is upload traffic between 8 and 9am (almost 2GB). You might want to set an upload limit to restrict the speed this can be accrued.
 Chris Parr
 Plusnet Staff
acarneiro
From personal experience, I would suggest you taking at look at services like Dropbox. They tend to have the potential of throwing your usage through the roof, especially if you have multiple computers and/or change files a lot.
