Incorrect Billing on Final Month of Contract
Lynnpin
Firstly my July bill is inexplicably for £27.02 instead of £17.74.  Can you advise the reasoning behind this and correct the figure please?
Secondly, the same thing happened at the end of my last contract.  A deliberate tactic I presume?
10 REPLIES 10
RealAleMadrid
Fixes: 66
Re: Incorrect Billing on Final Month of Contract
@Lynnpin  No you probably don't understand how Plusnet deal with the payments at end of contract. You may get charged for a month in advance and it will eventually be refunded when your final bill is raised which is about 3 weeks after your contract ends.
Lynnpin
Not very impressive then if that's the case.  I doubt they will refund anyone unless they complain.
Fixes: 334
It is auto-refunded after your final bill is produced, so leave your DD in place until the advised refund is in your account, then close it.
Lynnpin
Any chance of a Plusnet response please?
Fixes: 334
@Lynnpin Both @RealAleMadrid and I have been around long enough to give you a proper answer, and as I've left PN, I can assure you that is how it works.
LaurenB
Fixes: 131
Hiya @Lynnpin, thanks for getting in touch. I'm sorry for the delay in getting to your post and for the concern caused with your Billing.
I've taken a look into this for you and provided a more detailed response of what's happened on a ticket here for you: https://www.plus.net/wizard/?p=view_question&id=225864353 Please let me know if you have any further queries at all.
 Lauren Barry
Lynnpin
Hello again Lauren,
Thank you for initiating the support ticket for the refund.  However, although the "Charges Broken Down" section of my latest bill shows that the £9.28 overcharge has been deducted, it has also been added again at the bottom thus cancelling out the refund.
By my reckoning the payment should be £7.97 not £17.25.  Can you please advise?
Fixes: 1,638
The refund's been balanced out on the bill as it's a refund not a credit so you'd have received that in your bank account.
Can you confirm if you've received it?
Lynnpin
Hi @Gandalf,
Thank you very much for your help.  I was expecting a credit on my account rather than a refund so I have checked my bank account now and I can see that it has been received.
Thanks again.
Fixes: 1,638
Cool. No problem, let me know if there's anything else you'd need help with.
