Incorrect Bill
choo
Incorrect Bill
Hi
Please could ticked # 84944064 be looked at.
Also ticket #83576812 will help accounts see this months clear billing error.
Fixes: 62
Re: Incorrect Bill
I'm just looking into this now, it looks like a possible issue with the way we added some discounts as part of a deal.
I'll make sure this is corrected for any future bills that offer applies to and that you're refunded for this month's error.
Apologies for any confusion or concern.
 Adam Walker
choo
Re: Incorrect Bill
Thanks Adam for looking into this! Smiley
choo
Re: Incorrect Bill
Hi
Could this be looked at again
The  billing error looks like it  has been repeated .  Sad
ticket # 84944064  & #86008798
Plusnet Alumni (retired) LinnPlusnet
Re: Incorrect Bill
Hi choo,
Sorry this wasn't sorted the first time around! It seems like the discounts on your account were clashing and this has caused the discount to not be applied.
I have resolved this for you now and updated Ticket: 84944064 detailing what I've done and what discounts you should expect to receive and when.
Again, apologies this wasn't resolved for you last month!
choo
Re: Incorrect Bill
Hi
Please could  ticked # 195649861 just  be checked.
Hopefully this will be finally fixed before the next billing date.
Acassim
Re: Incorrect Bill
Hi Choo,
That number doesn't seem to link back to any support tickets, could you double check the number please?
On a side note, the ticket that Linn worked on looks fine and the discounting is set and ready to work.
Thanks,
Adam C
choo
Re: Incorrect Bill
The billing is still incorrect .
Question #86072718   /   Service Notice #197001244.
Please could this be finally fixed as it starting to get me down doing this every month since April.  Sad
Re: Incorrect Bill
Hi choo,
I can see that this has now been rectified. The billing was correct, you just had an extra month of the £5 discount before the new discounts started. The new discount will take effect on your next billing date. Hope this clears things up for you.
