How to answer a question
Iandgriffiths
I've just joined Plusnet and have been asked a question but can see nowhere to answer it?
The question came via email and is asking which of my two lines are they to take over?
4 REPLIES 4
shutter
Fixes: 65
Re: How to answer a question
@Iandgriffiths  Best way would be to get on to "Live Chat" sometime after 6pm as it will be quieter then...
https://www.plus.net/help/chat/
You may get a message saying your browser is blocking live chat... in which case. I suggest you download and install OPERA or Internet Explorer, and use them  "as is" with no settings applied.  It is easier than trying to figure out what is blocking  . keep either, or both as "standby" browsers and use only for Live Chat in future needs.
Fixes: 1,483
Moderators Note
This topic has been moved from Chat to My Account
OskarPapa
Fixes: 65
Hi @Iandgriffiths,
Thanks for your post.
If you can PM me your account username, I can check the account and then post a link to the question for you.
Iandgriffiths
Hi There,
Thanks for your reply but I got it sorted earlier.
Many thanks
Ian
