How long does it take to confirm the fibre install date
Fixes: 57
I selected a date with two options and looking at the ticket and despite a request for confirmation over 2 days ago there is no update
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: How long does it take to confirm the fibre install date
Just having a look at this Jim.
 Chris Parr
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Fixes: 159
The order has been placed again (it failed first time) but we haven't had confirmation of the date, we should know later today or tomorrow. I'll check back later on.
 Chris Parr
 Plusnet Staff
Fixes: 57
How long do BT usually need to firm up the date
Plusnet Staff
Plusnet Staff
Fixes: 159
Normally the same day the order was placed. The ticket you replied to dropped out to our team here as the initial order didn't go through correctly, so it was placed again.
 Chris Parr
 Plusnet Staff
Fixes: 57
So it has only just been placed
What would have happened if I hadn't posted on here or did someone actually check my ticket reply and do something - note the order should have been placed on the 23rd June
Plusnet Staff
Plusnet Staff
Fixes: 159
The ticket was being picked up when I looked at your account, it dropped out for the specific reason for the order to be looked into and replaced if needed.
 Chris Parr
 Plusnet Staff
Fixes: 57
So basically unless I had posted on here there wouldn't have been an order placed and I would have been in the same situation as http://community.plus.net/forum/index.php/topic,140918.0.html
This smacks of total incompetence and really screwed up systems which didn't pick up the fact that the order wasn't placed properly
I am going to be really peeved if I don't get one of the dates I requested
Plusnet Staff
Plusnet Staff
Fixes: 159
No, completely the opposite.
Your ticket was being worked on before I even looked at the account with the express intent of ensuring the order is place. That's precisely why the ticket dropped out to be looked at.
 Chris Parr
 Plusnet Staff
Fixes: 57
after 4 days of it being opened -
22nd Engineer Appointment Required
Manual appointment booking is required following an account change.
26th I have placed the FTTC order for you and provisionally requested the following appointment slots:
This really isn't good enough
Why wasn't the manual order initiated immediately or at least within the first 24 hours
Fixes: 57
I have just spoken to my neighbour who placed the order for fibre via COT about 1 hour after I did and provisioning have only just placed the order
So the question is
Why does it take 4 days for the contract change as agreed with COT to be converted into an actual order on BT by provisioning
This points to a really mucked up system where, apparently, COT raise a ticket for action by Provisioning which then goes into the normal queue and is finally acted on four days later
Plusnet Staff
Plusnet Staff
Fixes: 159
Because unfortunately the first order didn't get placed, when it attempted to be placed there was an error which dropped the ticket out for manual intervention. That ticket was picked up today, yes 4 days is longer than ideal but unfortunately that's how long it took Sad
The ticket wasn't raised by COT, the order was attempted to be placed via automation but hit an error.
 Chris Parr
 Plusnet Staff
Fixes: 57
Both of them  Crazy
Is this because the cab had only just gone live
