How long before a Referral shows?
Hello Folks
I had a call from someone I referred asking a question about their active Plusnet account. As they have signed up and apparently stated I referred them I was wondering why it doesn't appear on my referral list.
Does it take a while to show up or has something gone awry?
Peace be with you all.
pierre_pierre
Re: How long before a Referral shows?
I should appear after they pay there first months bill
When you say active, is the actual ADSL active or have they just signed up?
pierre_pierre
Have your checked here  that shows the active list even if not yet paying a referral yet
Quote from: Mark
They are using the account so it must be active?
Quote from: pierre_pierre
They don't appear on the list.
pierre_pierre
I would  PM Mark with their username, just in case they not put your details on the application
James
You're probably better off PMing me Smiley
Done,
Cheers
James
Hi God,
You should now be able to see your referral in your account.
It appears you also have godly powers James...
Peace be with you!
