How does the monthy usage spend work?
wrightgj
Hi all,
I am approaching my usage allowance this month and am likely to exceed it before the next billing period. My additional spend is set to £0. What physically happens to my connection once the 250GB threshold is exceeded? Will I still be able to use my connection, but in some limited capacity?
thanks
graham
Fixes: 57
Re: How does the monthy usage spend work?
speeds will reduce to 256kbps up and down 24/7
Fixes: 44
wrightgj
Geat thanks! Looks like the kids may be howling for a couple of days then!  Grin
Fixes: 44
They could always donate £5 from their pocket money for extra usage Grin
