How do i request a EPP code from PlusNet
FIXED- Subscribe to RSS Feed
- My Account/Billing
- How do i request a EPP code from PlusNet
24-03-2019 8:21 AM
Any ideas how I request a EPP code from PlusNet for my hosted domains?
Nothing on their help pages and several posts here with differing advice/problems depending on age of thread
Cheers
Eserim
Fixed! Go to the fix.
Re: How do i request a EPP code from PlusNet
24-03-2019 3:44 PM
Are you requiring this code to transfer your domains away? If so you can request this by raising a ticket here.
It actually doesn't look like you'd need an EPP code, though, as the domains listed are .co.uk domains. If you're transferring away you just need to notify us which domain(s) you're moving and the IPS tag of the new provider (by raising a ticket ).
24-03-2019 5:38 PM
Ta - the site I am moving to seemed to indicate the code was needed - but I'll go through their process and see what happ3ens when it sees it as a co.uk address.
24-03-2019 5:47 PM
No problems @Eserim,
Normally the process is that your current provider update the IPS tag with your chosen new providers tag. Once this is updated they can push through a name server change and complete the transfer from us to them. The process normally takes a day or so.
26-03-2019 9:03 PM
OK - the 1&1 wizard was misleading and it was just a tag change at the PN side, so I've put a call in.
Many thanks
27-03-2019 9:20 AM
Thanks for letting us know, @Eserim
If we can ever be of more assistance please do not hesitate to get back in touch.
Kind Regards,
MoR
