Home move / swap
marc
Home move / swap
I have broadband at home and also at a property I stay in during the week for work.
Work property = BT telephone & BT Infinity
Home = Plusnet telephone & Plusnet ADSL broadband
What I would like to do, is swap these around so I have Plusnet in the work property and BT infinity (still under contract so I can't change to Plusnet yet) at home. FFTC is available in my area.
Both Plusnet and BT offer home mover services. Will there be any problems if I use both of these at the same time?! What happens if they overlap?
Marc
All4One
Re: Home move / swap
I wouldn't have thought it was possible to swap both over when it's two different providers as one would try to place the order and obviously see it's already got services.
I think one way or another, one would need to be cancelled in some way and then maybe re-provided.
Hmm. You could try placing a migration order on both services, that should be possible - do it in the normal way and it should work fine.
