Home move confusion
lancewrite
Home move confusion
We plan to move house soon but can't get through to the phone help.
We currently have unlimited fibre extra and a land line.
The house we are moving to has EE fibre optic broadband and no land line. They say there was no option to have land line. They say we would have to disconnect and reinstall the old BT land line if we wanted a telephone connection.
Is this true? Has anyone else had this situation?
Thank you.
11 REPLIES 11
pjmarsh
Fixes: 20
Re: Home move confusion
Hi
It sounds like they may have FTTP.  If so, there may or may not be a copper line to the property, though that often isn't a mayor problem.
Best bet is to pop the details into here, and post back with the results (blocking out/removing any personal details as to phone number or address).  You may not have the details needed, though there is a link to an address checker at the top.  That isn't always as accurate but it will hopefully be ok for what we need at this point in time.
Fixes: 1,483
Moderators Note
This topic has been moved from Home Phone to My Account / Billing
lancewrite
Thank you. I used the address checker. The summary at the end said...
The exchange is not in a current fibre priority programme
WLR is currently available at the exchange
SOADSL is restricted at the exchange
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG premises served by 2.5 Inch plastic duct 56.
ONT exists with active service. No spare ports are available. A new ONT may be ordered.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
I'm not sure what the consequences of this are!
Fixes: 419
@lancewrite
If VDSL is not shown as available then you will need to change provider as Plusnet do not offer a FTTP service. You can still have your 'landline' phone, it's just routed through the 21st century fibre network, rather than the early 20th century cabled option to the exchange.
If you are in a Plusnet contract then if you move to EE or BT and talk to Plusnet nicely they may waive any termination charges.
Mustrum
Fixes: 77
Just to clarify, not all providers will allow you to keep your old number/offer digital voice - BT will, but EE won’t at this time.
Sight of the rest of the table would help give more information.
lancewrite
Thank you all for your help. I'm not sure if VDSL is available or not. The table says...
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date WBC SOGEA Availability Date
High Low High Low
VDSL Range A (Clean) help 44 31.2 8 6 27.4 Available Available
VDSL Range B (Impacted) help 42.8 27.4 7.9 5.9 22.4 Available Available
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
WBC FTTP Up to 1000 Up to 220 -- Available 1 Stage
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) Availability Date
WBC ADSL 2+ Up to 3 -- 2.5 to 6.5 Available
ADSL Max Up to 3 -- 2 to 5.5 Available
WBC Fixed Rate 1 -- -- Available
Other Offerings Availability Date
VDSL Multicast Available
ADSL Multicast Available
Exchange Product Restrictions Status
FTTP Priority Exchange help N
WLR Withdrawal help N
SOADSL Restriction help Y
Fixes: 419
@Mustrum
I was not aware of this. So EE are so keen on pushing their mobile service that if you want VOIP you need to go with a separate provider?
Mustrum
Fixes: 77
Seems a bit bonkers, but it is something to be aware of.
lancewrite
Here is the table:
Threshold(Mbps)
High Low High Low
pjmarsh
Fixes: 20
From that table you have three options:
  • ADSL, but only slow, but you could get it with Plusnet
  • FTTC (VDSL) somewhere between 31Mbps and 44Mbps, which you could get from Plusnet on what they label as Fibre
  • FTTP which it sounds like from your earlier posts that the current owner has, but Plusnet doesn't currently supply
You should be able to order one of the current Plusnet packages. You'd probably need to pay the £49.99 new line fee, and the engineer may need to install a cable from the pole to the property, or pull it through ducting (if underground), but that shouldn't be a major problem, or anything you need to worry about.  It would be for the engineer to take care of on the day.
With your speed estimates, you might not see much benefit from Fibre Extra, as the top end of your estimates are only a bit higher than the Fibre products top end.
lancewrite
Thank you for your assistance. It has been really helpful.
