Help assistant
- My Account/Billing
- Help assistant
Help assistant
05-06-2021 7:42 AM
Re: Help assistant
05-06-2021 7:46 AM
If you have raised a question, just log into your account - it should be on the homepage.
Re: Help assistant
05-06-2021 7:49 AM
Re: Help assistant
05-06-2021 7:52 AM
If you open the question - right at the bottom, it should say something like 'I need to add further comments'.
Re: Help assistant
05-06-2021 7:55 AM
Re: Help assistant
05-06-2021 7:59 AM
Ignore the email - open the question from the portal, and you should get something like this at the bottom:
Re: Help assistant
05-06-2021 8:04 AM
You cannot communicate with or reply to Plusnet via emails. They simply do not receive them, or if they do, delete them on receipt without reading.. As advised, reply to the ticket.
Re: Help assistant
05-06-2021 8:15 AM
Re: Help assistant
05-06-2021 8:28 AM
Try clicking on 'view' - far right.
Re: Help assistant
05-06-2021 9:09 AM
Its possible that the question has been raised as a 'closed' one. In which case there will be no option to add further details
Re: Help assistant
05-06-2021 9:17 AM
If it is showing on the OPs home page - it should be possible?
Re: Help assistant
05-06-2021 9:47 AM
Re: Help assistant
05-06-2021 10:05 AM
Re: Help assistant
05-06-2021 10:35 AM - edited 05-06-2021 10:36 AM
Deleted - irrelevant.
