Hardware (Router) Management Platform - how many?
DS
Champion
Fixes: 22
Is it just one router per account that can be 'registered' or unlimited or a set amount?
If it's more than one router, could this cause authentication issues?
TIA
8 REPLIES 8
Optimatts
Fixes: 19
Re: Hardware (Router) Management Platform - how many?
Hi @DS, in terms of the routers that get registered for authentication, the system does allow more than one router to be registered.
However, the main thing is that the system only allows an individual serial number to be registered to one account so there should not be any authentication issues as a result of this.
DS
Champion
Fixes: 22
As always, fanksalot Matt Smiley
So it allows more than one to be registered Smiley
And the system only permits one serial number ....?
But having been tinkering with TR069, why did it do this?
#415249391
Service Notification
10:06pm, Friday 17 May 2019
Your router has been disabled
Serial: +081441+NQ<redacted>276
OUI: <6x numbers redacted>
Model: Plusnet Hub One Type A
#415249392
Serial: +081441+NQ<redacted>390
OUI: <LNLLLN redacted>
(L letter N number>
So it had two router serial number registered, if I'm reading it right!!?
Fixes: 1,578
You can have more than one serial number on an account, but you can’t have the same serial number across more than one account.
Hope that helps.
DS
Champion
Fixes: 22
Fanks for that too Anoush Smiley
I thought that would be the case, as in a router (or routers) can only be attached to one individual user account at any one time.
I misinterpreted Matt's reply when he stated
As I'd read it that this meant an individual serial number per one account, which was my fault as I thought he'd contradicted himself with the first bit Embarrassed
So let's say there was going to be another software update, possibly after some recent issues are replicated, I could put one H1 on the network and it would auto update, then potentially I could swap to the other H1, your system would see this as out of date and this would also auto update?
Having said that, I'd of thought one would auto disable when the other was in use on the network and the second would miss the dinghy?
Or would the system try to send updates to all registered routers on one account, until such time all registered routers were known to be up to date?
(speaking of which, I'm thinking of putting one back onLips_are_sealed)
Fixes: 1,578
No problem. As far as I'm aware this would happen:
Having said that if a router is disconnected for long enough, I believe the auto-setup(TR069) will automatically be disabled.
DS
Champion
Fixes: 22
Thanks for that too Smiley
Case closed. I'll give Matt the fix if all are happy with this. He did reply first and actually answered it (if I'd read it right the first time).
Fixes: 1,578
No problem.
Case closed.
*Phew*
Booo.
But I guess he deserves the fix. Smiley
DS
Champion
Fixes: 22
@Gandalf wrote: snipped
Case closed.
*Phew*
Oh, I could go on, but, well, ya know.... Wink
Booo.
I actually did give a reason but then took it back out of the reply. Shh, If you really want to know, somebody has got some catching up to do!! (yes 590 v 9, but it's not about the numbers - though guess the higher ones get the better seat around the camp fire, or get the 'oi two sugars' privilege)
Well, somebody does deserve to feel wanted (and loved)
edit. "somebody does deserve to feel wanted (and loved)" then again, maybe not. He had 9 fixes, plus this one (on my fingers makes 10), but it's still showing 9.
