Failed billing error
- My Account/Billing
- Failed billing error
01-09-2019 10:22 PM
Re: Failed billing error
02-09-2019 9:52 AM
Welcome to the forums @waynz
Your post may be better suited in the My Account/Billing forum. Maybe a mod would be so kind to move it.
02-09-2019 1:14 PM
Thread moved from Fibre Broadband to My Account/Billing.
Forum Moderator and Customer
02-09-2019 3:31 PM
Hi @waynz
As far as I can see, your DD is active and we are not noting any failed / missing payment against your account.
Can I ask if you are still getting this failed payment notice?
Thanks,
MoR
02-09-2019 8:07 PM - edited 02-09-2019 8:08 PM
03-09-2019 8:41 AM
Thanks for the screenshots @waynz
I've raised this with the appropriate team to investigate further and I'd expect an update within the next 4 hours.
As soon as I know more I'll let you know. Apologies for the inconvenience this causes.
03-09-2019 9:35 AM
Hi @waynz
We've made a change to your account which I believe will hopefully have sorted the issue out.
Can you let us know how it goes the next time to go to browse to a site you couldn't go to previously?
04-09-2019 11:51 PM
05-09-2019 12:36 AM
Could you switch your router off for at least 65 minutes although ideally overnight/as long as possible to try to force your connection to assign itself a different IP address letting us know how it goes?
If you’re still seeing problems we’d likely then need to raise a task into our NetOps team to investigate further.
