Failed Bill / Bad Redirects / Connection Issues.
Fixes: 25
Re: Failed Bill / Bad Redirects / Connection Issues.
Hi @Lavodog1, sorry to hear that.
I have escalated your account to the relevant team for the restrictions to get removed which should be actioned within 4 hours.
Thank you for your patience.
 Faris
Macc2018
PN can you please take off the block on my broadband please.
Fixes: 18
Hi @Macc2018,
Thanks for getting in touch.
I've checked your details and can't see any account restriction in place. If you have called us about this today then it will have been removed, otherwise if you are having issues going online please do come back to us.
Thanks - Tahir
  Tahir M
mcgnso
Can you remove the restriction, please.
Fixes: 38
Hi @mcgnso
I have sent off a request to our back office team to have this removed for you. Please allow up to 4 hours.
Please accept my sincerest apologies for any inconvenience caused.
Kind Regards
 OllieC
tensulp16
I have the same connection and failed billing issue.
Fixes: 38
Hi @tensulp16
We're more than happy to help with these issues if you can please PM your account username?
Kind Regards
 OllieC
tensulp16
Check your PM.
Fixes: 43
Hi @tensulp16,
Thank you for getting back in touch with us. I have taken a look into your account and I've been unable to locate any fault with the services. With the issues you're experiencing, do they happen at certain times or does it happen randomly? Do they also occur across all of you devices and are they occurring over Ethernet cable connected devices?
 Alex H
Macc2018
PN
Can you please remove the block on my broadband please.
I did call the other day about this.
Username is [Removed].
Moderator's note by Mike (Mav): Personal information removed from a public forum (to an area that staff can see).
tensulp16
Yes - the issue happens randomly. This occurs across all of the devices using WIFI. I am not using an Ethernet cable at all.
Can I change my Plusnet community username to 'plususer16'?
Thank you for your help.
Fixes: 55
Hi @Macc2018, thanks for your post.
We've checked the account and are not showing any restrictions in place, and we're showing both upward and downward traffic.
Was the issue now resolved for you?
@tensulp16  - Changing your forum username isn't something that we're (Plusnet Staff) are able to do, but the mods may be able to assist. @Mav, Is that something you're able to help with?
I've checked the connection logs and we're able to see the below:
Does this tally with the drops you're seeing your side?
 Owen P
Fixes: 339
@OskarPapa
@tensulp16
We can certainly change the forum user name. To comply with the Forum Rules you would need to choose a name that doesn't have any part of Plusnet included.
PM any of the moderators with your chosen name and we will make the change for you.
Forum Moderator and Customer
tensulp16
I think these drops are when I reboot the router. In the end, I reset the router (by pressing the reset button for 7 seconds) on 25th Sep at around 3pm. I think that it solved the issue.
Fixes: 35
Hi @tensulp16, thanks for confirming, I'm glad it's resolved.
Please just get back to us if you require any further assistance.
 Lauren Barry
