Failed Bill / Bad Redirects / Connection Issues.
Fixes: 1,600
Re: Failed Bill / Bad Redirects / Connection Issues.
I've sorted that for you now. Although as discussed previously I've committed to removing the interruption for you as soon as possible once you've let us know it's applied and you can't bypass it, so it's best to send me a private message because this will ensure that I see it and it's dealt with urgently (I get all my PMs emailed to me, I don't always check my notifications bar)
Lavodog1
Please remove my restrictions bill will be paid in the next 48 hours
JARVIS
Good afternoon and thank you for your inquiries!
Apologies for the late response times also.
@Lavodog1 - Having a look at your account there should be no further restrictions going forward following payment. Could you please clarify this going forward for me?
Kind regards,
Matthew
 Matthew Bullimore
Macc2018
Can you please remove the block on my broadband please.
abails0105
Fixes: 60
Hi @Macc2018, thanks for getting in touch
It looks like restrictions have since been lifted and the service has restored to normal.
Let us know if you need anything else.
 Alice Baillie
Mandy369
i have same issue restrictions please can you fix for me
Macc2018
Can you take the block off my broadband please.
Macc2018
I called yesterday to get block taken off our broadband and was told within 2 hours and some 12 hours later its still there.
so looks like the guy i spoke with has not done it so again can you please take of the block please.
Moderator's note by Mike (Mav): Duplicate post in another thread removed.
boo1
hi  macc2018    if   you   go  to   the forum  pick  up   any   body   having   the    same   problem   as   you   that   is   getting   help   from   the   plusnet   help   team   I  am   sure   that   the   help  team  will   pick   this   up   for   you   hope   this   helps   from  boo1  thanks
Macc2018
Hi PN
Can you please take off the block on my broadband please as it should not had gone on which it has.
Lavodog1
Can you please remove restrictions from my account. Bill will be paid on the 5/10/20
Fixes: 1,600
Thanks for getting in touch @Lavodog1
I've removed the restrictions for you now
Let us know if there's anything else you'd need help with
jellybeanz
Hello there,
Finding it impossible to pay my bill as the plus.net site is blocked, as is plus.net/pay. Most of the internet works as normal but the one site I need is blocked!
jellybeanz
Still blocked from viewing plus.net and unable to pay.
haywardsteve
New month same problem!!!!!
When are plus net going to fix this problem as its now the 10th month it has happened?
Moderator's note by Dick (Strat): All caps title/text edited as per Forum rules.
