Failed Bill / Bad Redirects / Connection Issues.
Beyhive
Fixes: 44
Re: Failed Bill / Bad Redirects / Connection Issues.
Can you please try again now @mcgnso?
 Faris
mcgnso
Still restricted.
RandallFlagg
Fixes: 75
Sorry that this hasn't been resolved yet, @mcgnso
I've just submitted a manual request to get this removed for you - could you please let us know if you're not back online in the next few hours?
Best wishes
Dave
mcgnso
Still restricted. Getting annoying now as I can't access a program I need to use.
SammyM
Fixes: 96
Hello @mcgnso,
I am deeply sorry that our efforts to remove this browsing interruption has not worked and I have raised this with the relevant team to get this resolved.
I will personally monitor the issue and update you via the account here once the issue is resolved.
 Sammy M - Sheffield Team
Macc2018
Can you take my block of again please.
OllieC
Fixes: 46
Hi @Macc2018
Thank you for getting in touch.
I have manually removed this for you. We're really sorry for any inconvenience caused.
Kind Regards
Lavodog1
Please remove my restrictions bill was only due yesterday this is the 3rd time !
MatthewWheeler
Fixes: 479
Thanks for getting back to us @Lavodog1
We've removed the restrictions from your account so you should be able to browse normally.
If you're still having issues please try rebooting your router
 Matthew Wheeler
Lavodog1
This has happened again please remove
SammyM
Fixes: 96
Hello @Lavodog1,
I have removed this for you and you should now be able to browse normally. If the browsing restriction is still present please can you reboot your router and get back to us if the issue persists.
Lavodog1
Again they are bk on
Fixes: 160
Have you paid your bill? That is usually a good fix for this ‘issue’.
However some users report difficulties being able to access the pay now screen or make contact with support to pay over the phone - have you encountered these issues as well?
Many find that having a DD mandate in place makes this problem go away for ever - have you tried that solution?
MasterOfReality
Fixes: 57
Hi @Lavodog1
I have removed the restrictions again.
Please ensure you make payment within the next 3 days in full to prevent further restrictions being applied to the account.
Kind Regards,
MoR
smiffy1
@Townman  "Have you paid your bill? That is usually a good fix for this ‘issue’." sounds a bit condescending Sad
we know you are trying to help , this is not helping .
