FTTP being installed now but need to keep landline - not worried about my IP address changing.
robsinglehurst
Re: FTTP being installed now but need to keep landline - not worried about my IP address changing.
From those stats then would it be just more sense to accept PNs upgrade offer?
Fixes: 303
@robsinglehurst Which Hub/router are you using? Your speed is below the Hand back threshold, so we need to do some investigation.
Fixes: 303
No, we need to investigate why your speed is below the acceptable.
robsinglehurst
Currently using a BT Smart Hub 6 setup with my Plusnet login info but frequently have to power cycle it. The Plusnet Hub One has about the same reliability.
Fixes: 303
OK. I don't know the BT 6, but can you provide the details requested in the script below?
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
Hannah4
Hi Rob, I think you mean Phonely.co.uk They are only £9.97 per month for unlimited calls.
Fixes: 66
@Hannah4
What is called "Fibre" is actually FTTC - the fibre optic cable is run to the Cabinet and then uses the copper cable to reach your house. You're being offered the same connection but without the phone service. The OR product used for this is known as SOGEA.
"Full Fibre" is where they run a fibre optic cable direct to your house. It not only bypasses the Cabinet but may go nowhere near your current Exchange - it runs direct to a major Exchange that has an "internet Head End" (the connection to the wider web).
Virgin are building their own network. If you wish to get a service from them when it's live then it's totally separate from your PN service. Indeed, you'd be running two accounts until such time as you cancelled PN (with any associated early termination changes).
HPsauce
Seasoned Pro
Fixes: 4
@robsinglehurst said "Currently using a BT Smart Hub 6 setup with my Plusnet login info but frequently have to power cycle it."
Frequent power cycling can be seen as a fault which will restrict speed, that could be the core of your slow speed problem. A router would not normally need to be power cycled to overcome a line issue so this suggests your router is more likely the issue.
And "The Plusnet Hub One has about the same reliability." however I'd revert to using that as PN are much more likely to take note of the stats from it and take action if needed.
robsinglehurst
Hi John,
Sorry for the delay, I was hunting around for a Cat5 cable. Here are the results. Just a laptop plugged into 1 network socket (Plusnet Hub One), 2.4Ghz and 5Ghz WiFi turned off.
I ran the 17070 Quiet Line 2 test and the line is quiet - we only have a Panasonic DECT cordless unfortunately.
Guessing there is something not quite right......
Fixes: 303
Cheers, @robsinglehurst . As you have the Hub one connected, can you please post the broadband connection status - navigate to the Help Desk page, but remember to obscure your username.
Fixes: 66
Sorry about this - I tagged a post earlier with @Hannah4  when it appears it should have been @robsinglehurst
robsinglehurst
Fixes: 303
Not quite what I was looking for, @robsinglehurst - it is the Hep Desk page which gives the information   we need. It is on the 'Troubleshooting' tab.
robsinglehurst
Hi John,
Sorry about that!!🤣
Fixes: 303
@robsinglehurst Thanks. If your phone line is silent on the test, I suggest you report a broadband fault via https://www.plus.net/help/report-a-problem/ - your downstream noise margin is elevated, indicating an OR network issue.
