Error: You can't change your products for the moment, order is being processed
livdev
Hi I've added the Anytime package to my phone line, but it's been stuck in this loop for over a day.
Please help, thanks!
1 REPLY 1
Fixes: 1,600
Re: Error: You can't change your products for the moment, order is being processed
Hi @livdev,
From what I can see that error is caused by the package change you've put through which is due to go live on your next bill date the 24th October so if you can check back then you should find the error has gone away.
Let me know though if you have further issues or there's anything else you need help with.
