Enhanced Care order stuck
jmcgarrigle
Hello,
Enhanced Care activation was started on another line I look after on the 24th December, and confirmed as active on the 31st Dec. On my line, activation was requested on the 18th December, and according to portal is still in progress today..?
Also, there is a spelling mistake on the control panel; My Account > Control Account > Add Enchanced Care
Is enhanced care available for Residential Lines also, albeit not via the control panel? I see some mentions on the site that it might be...?
Thanks,
-J
Re: Enhanced Care order stuck
Hi there, looks like the order was completed on Tuesday morning and your account has now been updated?
Thanks for the heads up about the spelling error, I'll get that raised to our content team who'll get it sorted.
Finally, no I'm afraid Enhanced Care isn't available on residential lines, it's only for business accounts I'm afraid.
jmcgarrigle
Hi Matt,
Still showing as pending on my end. Are you sure we're talking about the same account? It should be the one linked to this forum account...
Thanks,
-J
jmcgarrigle
Anyone?
Fixes: 32
Hi, having checked the account linked to your community login enhanced care is active so everything looks OK with that from our point of view.
Adam
 Adam Walker
jmcgarrigle
Hi Adam,
I wonder if it's somehow linked to the wrong account - I have several. Will PM you the username.
Thanks,
-J
Fixes: 32
Cheers, just looking at this now. I'll reply to your PM shortly.
 Adam Walker
Got your PM, thanks - I can see you talked to one of our support team yesterday and they've replaced the order for you (that is a totally different account to the one that's linked with your forum ID!)
The order's completed this morning and your line is now showing the correct care level for Enhanced Care - hope that's your finding as well?
jmcgarrigle
Good morning Matt,
Yes, I'm not sure how to change which account my forum username is linked to - the account I PM'd you is far more likely to be the one I'm discussing on here.
Good to hear the order has completed. It's not showing on my account, but I understand that due to a billing hiccup I'll need to make a pro-rata payment for the service this month in order to have it activated. I've been told that'll happen today.
Thanks for your help!
-J
