ERROR: The account has no invoice in Failed Billing
- My Account/Billing
- Re: ERROR: The account has no invoice in Failed Bi...
17-02-2018 11:34 AM
I started getting this error message today whilst trying to access some sites. My account is fully paid up.
This follows a few days of various issues such as:
"No internet" messages on various devices i.e. Mobile and Tablet via WiFi, PC via Ethernet Powerline, etc.
Can anyone help, please?
Re: ERROR: The account has no invoice in Failed Billing
17-02-2018 12:52 PM
Moderator's note by Dick (Strat): This thread is now in the appropriate board.
17-02-2018 1:07 PM
There does not seam a lot of staff around at the weekends
You may have a long wait till monday
17-02-2018 3:35 PM
@MysteRon This error has been reported before. Not sure what causes it apart from some screw up in PlusNet's systems. The general advice is to disconnect your router for over 1 hour then try a reconnect, whether PlusNet have to do something at their end I don't know but you could give it a try.
17-02-2018 5:43 PM
Hi there
I would check to see if you are unknowlingly connecting via your Power Line adaptors to a neighbours Power Line network, that is to say, someone nearby who is also using the same type of adaptors . Disconnect your PL plugs, turn them off unplug them and reboot your router and all your devices. Do not plug in the adaptors . See what happens. If you can then successfully connect to the internet then the PL adaptors may be the reason for your your problems .
You may be able to solve this by setting up your PL adaptors with a specific network name and password, As recommende by manufacturers, But I would get rid of them and use an ethernet cable instead.
19-02-2018 8:01 AM
This error has been reported since 2011 having searched the forum archives. I've also lost an entire weekend of access, spent several hours on the phone mostly on hold, and yesterday was finally told it could be a few days but less than 7 before I'm back online.
Seems the issue is linked to IP addresses associated with accounts that go overdue. Plus.net's back office management system is unable to handle the fact IP addresses are allocated on a dynamic basis, thus the poor fool who gets assigned one of these blacklisted IP addresses pays the penalty for the non-paying customer. 7 years on and they haven't addressed this issue. Great customer service Plus.net - you really are doing yourselves proud!
Meanwhile I'll be contacting the regulator today - I don't see why I should be locked into a contract until December 2018 when this issue could happen repeatedly.
Having hiked my price, forced me to upgrade to higher speeds because i needed better than ADSL upload speed, yet can't benefit from the 76mbs download speed, only to then remove the upload cap on the lower speed for new customers, Plus.net have proven themselves to be nothing but sharks. This latest issue is the final straw.
19-02-2018 9:06 AM
Yeah, phones very busy too.
Tried recommended work rounds and finally after switching router off for a couple of hours, it seems to have cleared it.
19-02-2018 9:10 AM - edited 19-02-2018 9:11 AM
Hi All,
Finally after switching router off for a couple of hours, it seems to have cleared it.
For how long.............
20-02-2018 8:51 AM - edited 20-02-2018 8:53 AM
A warm welcome to the forums to both of you.
The answer to your question is that if your connection is stable, you do not reboot your router then you should not see the problem again. This issue is on the SU's radar.
I will raise the question of the "7 Day wait" advised to you - that seems somewhat odd.
Superuser citation
This topic has been cited by one of the Superusers; the purpose of which is to provide a note for information which might help to focus continued discussion (but might not result in a staff response).
20-02-2018 9:01 AM
This problem has been on radar since 2011! A simple search of this very forum will attest to the number of users that are affected with this problem.
And the connection was always stable - just unable to browse, send email, use VPN etc - but Netflix streaming and Smartthings connectivity worked - possibly Net Neutrality at work there?
The fact is, to clear the problem the router needs to be off long enough for the PPP session to drop allowing a fresh IP address to be assigned when the router is powered back on 70-90 minutes later.
What would be helpful is if this information was given by customer services/tech support rather than hunting it down on a forum, discovered by another user as the issue/fault resolution.
20-02-2018 10:47 AM
Indeed, there are a few things which have been on the radar for a while around here.
I believe that this issue had been discussed by the SUs and had been mitigated ... I have just re-asked the questions.
To be clear, the magic wait time is 65 minutes and it is more a matter of hoping that a different IP address will be allocated.
