Downgrading broadband package
GeordieMark
Morning guys,
Since it looks like I'm stuck at 43Mbps on my line I was looking to downgrade to the cheaper up to 40 service, but I can't see anywhere in my member centre to do it.
Am I just being blind or do I have to request this another way?
Cheers
Mark
Fixes: 247
Re: Downgrading broadband package
You need to call up for that, can't be done online
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
GeordieMark
I was afraid of that, thanks for confirming though!
matthews
Hi Mark_
I may end up having to do the same, how did you get on with them? Were you in a contract when you contacted them?
MattyC
Champion
Fixes: 46
Hi matthews,
It's likely that you'd be recontracted.
I would suggest contacting our Customer Options team on either 0800 013 2632 or  0330 123 9197 to see if they can offer you any deals.
There's no queue at the time of writing this.
Matty
matthews
Hi MattyC
Thanks for the advice. I'm only a couple of months into an 18 month contract so not expecting it to be straightforward. Going to give it some time to settle first and make sure there's nothing at my side that's responsible for the "slow" speeds (in quotes because I never thought I'd see the day where I considered 30mbps internet slow!)
MattyC
Champion
Fixes: 46
Quote from: matthews
Just goes to show how far we've come.
Let me know if there's anything I can do.
Matty
