Direct debit question
paulgul
Due to the impending charges for card payments I have set up a direct debit, the DD status is shown as active but my cards are still showing primary and secondary payment methods. Does a DD automatically take priority over card payments or should I now delete the cards, I'm a bit worried about doing the latter as I understand there should always be 2 payment methods in case the primary method fails.
Paul
4 REPLIES 4
Fixes: 1,483
Re: Direct debit question
Hi Paul,
I'm in the same position and have been told that DD is used if it is set up and not CC.
HTH
Peter_Vaughan
That is my understanding also.
However, I would recommend keeping at least one card on the system for the next few months in case there is an issue with DD (especially the first payment). The card will be used if the DD cannot be taken. Once the DD is working fine you can remove all card details.
pierre_pierre
and if you take any odd balls like a free router, they take the postage via a card
paulgul
Ok, thanks for the replies. I'll keep the cards on there just in case of a problem.
