Direct Debits Very Short Notice
vignamic
One to be aware of. PN are not doing things correctly, They are using the old Invoice method to bill and charge us.  They only give around 2 days’ notice from invoice. I have spoken to Bacs Ltd and they have advised that it should be 10 working days’ notice. Watch your bill they may send you an invoice on the Friday and take the money on the Monday! They are not going to change this. So beware when you receive your invoice email check it asap.
Jonpe
Aspiring Champion
Fixes: 6
Re: Direct Debits Very Short Notice
When DDs were first introduced I think there was a requirement to give the customer three weeks' notice of the amount and the date it would be taken from his/her account.  Since then the time has been progressively shortened; I think it's something like ten calendar days with BT, and with PN it's now down to three calendar days (in reality it seems to be more like five days until the amount leaves your account, then another day or two before the PN account is updated).
vignamic
I know I used to work for a Bacs Software House. It went from 3 weeks to 5 days and 10 days if you changed the amounts. I have had a response from Bacs Ltd who tells me all should now be 10days from invoice and/or 10days if the recurring amounts change.
Other companies like BT, Talk Talk, Sky and other suppliers use a system of recurring amount and invoice every quarter. This means you are in more control and can query any amounts. I was just warning people to keep an eye on their invoices as PN will take the money very quickly.
Plusnet Staff
Plusnet Staff
Fixes: 117
The advance notice period of a direct debit can depend on the organisation. For us, the advance notice period is 3 working days as advised when you setup the instruction.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
vignamic
Hi Anoush,
This is just a warning to all that 10 days (Set by Bacs Ltd and by SEPA Direct Debit) is the normal way of running Direct Debits from invoice is. As there is no time to check the invoice and stop the DD if needed. But you already know this.
I think you need to change this to how BT (Your owners) and other compaines do things.
vignamic
Has this just been changed? As when we singed up there was no time scales.........
Has the T's&C's been changed without telling anyone?
Fixes: 10
A bigger problem is that if you receive a DD notification for an incorrect amount and you contact them within seconds of them sending the email it is already too late for them to correct it.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
