Direct Debit
Donyatthall
Direct Debit
We have tried to set up a DD but as the account needs 2 signatures it fails on line. How can we set up the DD ?
Pete11
Seasoned Pro
Fixes: 4
Re: Direct Debit
When we ordered Plusnet, direct debit was set up with no problem. My wife ordered the broadband and phone but I pay for it through direct debit. I gave PN my card details and that was that. They didn't need a second person.
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
Fixes: 5
Re: Direct Debit
I had the same when setting up a couple of business accounts.  Plusnet gave me a link to a PDF which I printed, got the signtures, and then I think I scanned it and attached it to the ticket.  You probably need @Gandalf or another member of staff to send you the form.
Fixes: 441
Re: Direct Debit
Hi there.
I can provide you with a PDF if you would like to setup your direct debit instruction by post, but I'd expect the online DD to go through fine. It typically can take about 14 days to be processed.
Let us know if there are any problems or if you want the PDF instead?
Donyatthall
Re: Direct Debit
Thanks Gandaff
We have tried 3 times to set up a DD online but e think because our bank account requires 2 signatures for any transactions the bank rejects the set up .
If you could provide a PDF form and a return address / email we can send or scan it back to you.
regards
Fixes: 441
Re: Direct Debit
It looks like the direct debit has activated now.
I'd expect the payments to be taken from it normally.
Donyatthall
Re: Direct Debit
That sounds great !  Many thanks.  The account did say pay by cheque so I'll check this has updated before closing this thread.
Donyatthall
Re: Direct Debit
I cannot check if the payment method has changed as there is an outstanding bill ?  Can't understand why this has not been paid via the DD ?
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
Fixes: 441
Re: Direct Debit
It's likely because it was generated before the DD activated.
If you click here it should take you to the payment details page where you can check your current payment method.
Donyatthall
Re: Direct Debit
Checked and set up OK.  Many thanks for your assistance, it's been a real challenge getting to this point.  I'll get the Treasurer to settle the payment.
Fixes: 441
Re: Direct Debit
No problems, I’m glad to hear it’s finally sorted. Smiley
