Data allowance exceeded, payment limit raised, but speeds still capped?
- My Account/Billing
- Re: Data allowance exceeded, payment limit raised,...
05-06-2012 11:26 AM
I exceeded my 'Option 2' data allowance of 15GB, and my broadband speed was heavily capped.
As per an email I received from PlusNet, I went to the following link (https://portal.plus.net/my.html?action=control_your_broadband) and increased my monthly spend by up to £10 to cover an additional 10GB. However, my broadband speeds still appear to be significantly capped.
Anyone know how to get the cap lifted immediately?
Thanks,
Peter
Thanks,
Peter
Message 1 of 6
(1,758 Views)
5 REPLIES 5
Re: Data allowance exceeded, payment limit raised, but speeds still capped?
05-06-2012 11:42 AM
I suspect that you have fallen foul of the same problem I had.- a product mismatch on various systems
I suggest calling to try to sort it out
As a matter of interest what did the email say - if it said you could add £5 extra lumps then there is definitely a product mismatch as on Broadband Your Way Option 2 it should be in 1GB chunks
Message 2 of 6
(502 Views)
05-06-2012 11:55 AM
Thanks.
The email and the web control panel allow for 1GB increments.
Quote from: Oldjim As a matter of interest what did the email say - if it said you could add £5 extra lumps then there is definitely a product mismatch as on Broadband Your Way Option 2 it should be in 1GB chunks
Message 3 of 6
(502 Views)
20-06-2012 11:16 AM
Message 4 of 6
(502 Views)
20-06-2012 2:04 PM
This is fixed now. One of the PlusNet support team brought forward my switch to the new package.
Cheers ...
Cheers ...
Message 5 of 6
(502 Views)
20-06-2012 2:12 PM
Message 6 of 6
(502 Views)
