Dashboard on Plusnet Member Centre
- My Account/Billing
- Re: Dashboard on Plusnet Member Centre
22-10-2022 10:26 AM
I'm trying to access the dashboard for my account on the Plusnet Member Centre. It loads up and then promptly disappears rendering it unusable. I spent a few minutes trying to catch the link to Bills before it disappeared and manged to move on eventually. I did think it might be a web browser issue but trying it on another browser makes no difference.
22-10-2022 10:37 AM
See this thread:
If you look at the last few posts you will see how to access pages other than the home page which is where the problem lies. It is not a browser or operating system issue but lies with the home page coding.
22-10-2022 10:37 AM
See: https://community.plus.net/t5/Everything-else/Plusnet-Broadband-portal-not-displaying-correctly/td-p... - already under investigation.
22-10-2022 11:00 AM
@jgb @jab1 Thanks for that. Once you've logged on this will take you to the billing section https://www.plus.net/member-centre/billing-payments/billing-history which is probably where most people would want to go initially.
22-10-2022 5:44 PM
I am experiencing exactly the same problem, which has been going on for over a week. I phoned the 'help' number and was told there was an issue at the Membership Centre. I find that I am welcomed, my last account details appear and immediately disappears. What on earth is going on?
22-10-2022 5:51 PM
@street7cat See the two posts immediately above yours.
24-10-2022 1:17 PM
Hi @Moz,
I've added your account to the ongoing investigation, thanks for the heads up!
