Current Referrals not displaying
pd
Is anyone else seeing this problem?
As soon as I click on Current Referrals from the Member Centre menu all I get is a blank screen.
Peter
Fixes: 12
Re: Current Referrals not displaying
Checks out OK for me?
Maurice
pierre_pierre
I did check it earlier and found the same problem, now seem to have been rectified - no comments from PN though
Fixes: 6
Could it be the same as what Maurice reported last month and then mysteriously fixed itself?
Phil
James
Hi pd,
Whilst I haven't tried logging into your account as of yet, I've gone into your referrals through our own system and haven't been able to see the issue that you're reporting.
Can you try again for me and see if you are still experiencing difficulties?
James.
The white screen issue happened a few weeks ago.
I think it needs a problem raising. The screen grab is above for poc.
James
Thanks Mark.
It's been raised as Problem 52184.
Roo
I've had a quick look at this and managed to replicate the issue! It looks like there's a library missing off one of the servers, hence why the issue is so intermittent.
Now we know what the problem is we can get it fixed!
Grin
As always. Loving your work Rupert Smiley
Thanks buddy.
pd
Thanks Guys...  This is the same problem Maurice first reported as Phil mentioned.  It appears OK this morning though.
Peter
Roo
Our lovely network people have installed the offending library on the server it was missing from, so we should no longer see the mysterious white page issue on the referrals screen. At least not until I've had chance to break it again.
Grin
Fixes: 12
These intermittent problems are little B£$%&r's to find aren't they Grin
