Couldn't remove db entry
Every time I log out of my account I get this message "Couldn't remove db entry". This happens with any browser and any PC I login from.
What needs doing to fix this error?
Dan.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Couldn't remove db entry
Hi Dan,
This is a problem from our end which affects free-online accounts. Problem: 77873 has been raised in order to track and resolve this issue.
When you logout, if you refresh the page, this should resolve the issue for you.
Chris Pettitt
Cloud Environments Engineer
Chris,
Many thanks for your quick reply, confirm refresh clears the issue.
Dan.
