Confused by price increases - can someone explain?
WalnutTree
Hi
I'm on a broadband contract for £18.99 a month and the contract started on 01 Feb 2022.  However, I was charged for £19.86 for February 2022 instead of £18.99.
Here are the bills so far:
- Feb: £19.86
- Mar: £21.22
- Apr: £17.89 (correction for overpayment)
- May: £20.92
- Jun: £20.92
I know that there was a CPI + 3.9 price increase from 1 March 2022. The £20.92 charges for May and June mean approximately a 10% increase to the original price: £18.99 + £1.93 (10%) = £20.92. Is this correct?
It's very confusing how this has been calculated.
Could someone explain the billing above and also confirm if the billing is correct? Thank you
6 REPLIES 6
Fixes: 457
Re: Confused by price increases - can someone explain?
@WalnutTree
The increase was 9.3% so I reckon it should be £20.76. I have no idea how Plusnet’s billing system works it’s own version of magic.
WalnutTree
Thank you @Baldrick1 for letting me know about the 9.3% increase. As you mentioned 9.3% comes to £20.76, but I also don't know how billing does its calculations. The bills do not provide clear explanations.
I hope Plusnet update their CPI Plus 3.9% Guide to include the 9.3% figure.
Fixes: 1,639
I'm really sorry for the confusion here.
I've taken a look at this for you and I believe I've sorted things out. I've dropped you an email with more info which you can also view online by going here > https://www.plus.net/wizard/?p=view_question&id=225040274
If you've got further questions though, feel free to let me know.
WalnutTree
Thank you @Gandalf for the email with more info and for correcting the billing. Many thanks.
Fixes: 1,639
No problem @WalnutTree, let me know if there's anything else you'd need help with.
Fixes: 236
@Baldrick1 wrote:
@WalnutTree
Think I'm losing the plot here ... if the pre-increase charge was £19.86, then adding 9.3% (£1.85) makes the new price £21.71.
The first bill following 31st March will be higher than this as it will have an adjustment for the days billed in March from 31st March to the April billing date.  The bill for May should then be £21.71.
