Charge for calls to mobiles
Fixes: 31
Hi
I am on an evening and weekend calls deal, but I seem to be getting charged 29p every time I call a mobile at the weekend.
I thought you got 100 mins free?
dick:green Excessive white space removed.
Fixes: 62
Re: Charge for calls to mobiles
Only if you take the 100 minutes mobile extra which I think is £3
Fixes: 178
The details of our Evening & Weekends call plans can be found Here
The 100 mobile minutes are an optional add on for £3 per month as Oldjim said. If you were to add this to the call plan, the 100 minutes could be used any time, not just in the evenings and weekends.
I hope this helps.
 Harry Beesley
Fixes: 31
Thanks both, yes it helps.
Its taking me a bit of time to get used to having to pay for calls, after 15 years of free telephoney Wink
