Changing tariff
- My Account/Billing
- Re: Changing tariff
Changing tariff
16-07-2012 11:41 AM
We have a property that will get more usage in a few months of the year than others.
How often can I change tariff ?
Having just been charged for excess use, if I "up my tariff" will that be in addition to the £5 already charged ?
thanks
(couldn't easily see this on the Plusnet pages direct, and went round in circles trying !)
thanks
Message 1 of 8
(6,007 Views)
7 REPLIES 7
Re: Changing tariff
16-07-2012 11:47 AM
Once per month and will take place at the account month end normally
It can be done immediately but not via the normal upgrade process - you need to raise a ticket
Any extra usage already paid for will be ignored (using the standard system but can be over ridden at the discretion of the agent when the change is immediate) in calculated the cost increase which is related to the change in base tariff only
Edited to reflect the clarification by the other Chris below
Message 2 of 8
(802 Views)
Re: Changing tariff
16-07-2012 11:55 AM
thanks, sounds like I will get taken for that extra £5 this month then (we have used 10.31GB of my 10GB allowance, didn't spot the email warning me in time 😞
I can only see the "product change" which I think is the "normal upgrade process" - how would I "raise a ticket" - can I do this online ?
cheers, appreciate the rapid reply !!
Message 3 of 8
(802 Views)
Re: Changing tariff
16-07-2012 12:03 PM
Hi mikeiow,
I can get this arranged for you straight away, putting you on the Extra package with 60GB of usage, this will wipe out your additional charge that you incurred for extra usage :), let me know and I'll get this done straight away for you.
Chris
Chris
Message 4 of 8
(802 Views)
Re: Changing tariff
16-07-2012 12:14 PM
Chris,
Is this the normal procedure or are you doing a special.
If normal I will edit my post
Message 5 of 8
(802 Views)
Re: Changing tariff
16-07-2012 12:50 PM
Normal procedure is on the next billing date, however we've been doing instant ones where we believe it's good to do so manually for a while.
Message 6 of 8
(802 Views)
Re: Changing tariff
16-07-2012 12:56 PM
That wasn't the bit I was querying - it was this
Quote from: chrispurvey Hi mikeiow,
Chris
Message 7 of 8
(802 Views)
Re: Changing tariff
16-07-2012 12:58 PM
That's not automated, that bit is at our discretion simply because account changes aren't supposed to happen until the next billing date.
Message 8 of 8
(802 Views)
