Changing plan & nearing limit
- My Account/Billing
- Changing plan & nearing limit
18-03-2013 6:28 PM
I have just realised that the unlimited usage plan costs only slightly more than the 60Gb plan that I am on, as I have started using more of my allowance & am fast approaching my limit with more than half of my billing window left I decided to upgrade.
I asked if there is anything I can do to avoid incurring a potential £60 extra charge for the remainder of this slot, only to be told to put a limit on it.
I was not asking for something for nothing, just a bit better deal than the £5 for 5Gb.
Message 1 of 3
(792 Views)
2 REPLIES 2
Re: Changing plan & nearing limit
19-03-2013 9:20 AM
Looks like we've been able to force that one through for you, hope it helps.
Message 2 of 3
(362 Views)
19-03-2013 9:43 AM
Thanks Matt I appreciate that
Message 3 of 3
(362 Views)
