Change product or not?
- My Account/Billing
- Change product or not?
15-06-2011 2:23 PM
Hi
I'm currently on this package:
PlusNet Broadband Your Way Option 1 (Monthly Contract) - 2GB Limit
£9.99
2GB Additional Usage
£2.00
Talk Anytime International 300 (Monthly Contract)
£5.00
Line rental
£11.99
Would it be worth switching to Plusnet Value with talk anytime? My internet usage is steadily increasing and I've used 6GB+ before in a month. I dont make any international calls at all.
£9.99
£2.00
£5.00
Line rental
£11.99
Message 1 of 3
(713 Views)
2 REPLIES 2
Re: Change product or not?
15-06-2011 3:12 PM
If you don't change the phone package and focus on the broadband, the pricing for value will be £6.49 for three months and then go up to £12.99 a month (you're in a market 1 area).
Therefore you'd get 10GB of usage for £11.37 a month (averaging the price over 12 months that is) which does work out cheaper than the 4GB you currently get for £12.99 a month. Even if you don't take the lead price into account, it's still £12.99 a month for 10GB instead of 4.
It is worth bearing in mind that extra usage costs are £5 for 5GB on value rather than the £2 for 2GB on your current product, but as you state above that you don't exceed 6GB generally this shouldn't be an issue.
Hope that helps,
Hope that helps,
Message 2 of 3
(272 Views)
15-06-2011 3:25 PM
Very helpful Matt, thanks a lot
Message 3 of 3
(272 Views)
