Change of Product - Do I loose my IP address
matthewleggott
I am looking to change my package from Broadband you way option 3 (19.99) to the Extra Package with 60gb bandwidth but I have a question.
I have had the same static IP address for numerous years would I still keep this one when I change package?
Fixes: 62
Re: Change of Product - Do I loose my IP address
In theory yes - but I make sure you raise a ticket saying that you want to keep it
I've changed account types a few times over the last 10 years with PN and yet to lose my IP address I got when I was on 56k.  but I have always stated in the ticket to keep all existing Features, IP address/web space etc
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
matthewleggott
Thanks for the replies I will raise a ticket.
mapletree
AFAIK some products have a particular range of IP addresses and if you change you will be assigned an IP from a different range.  My static IP address was changed when I moved from Home Surf to BBYW, despite assurances that I could keep the old address.
matthewleggott
Well I have made the move and have the same address Smiley
