Change account password?
BEST123
When I try to change my password an error message is given me.
The message is: Response Code 403
What does this mean?
24 REPLIES 24
Fixes: 1,483
Re: Change account password?
Moderators Note
This topic has been moved from ADSL Broadband to My Account / Billing
abails0105
Fixes: 60
Hi @BEST123, thanks for getting in touch.
I am sorry to hear you're having issues changing your account password. Can you confirm if this error message occurs on different browsers when trying to amend the password?
Regards
 Alice Baillie
BEST123
I had used Safari but this time used Chrome which gave the same error message, that is  " Response code 403".
The web page was https://www.plus.net/my.html?action=change_password&s=0
I hope this is of help.
Michael
ffox
I can't log in to my Broadband account.   My old password was not accepted so I changed it.  The change was acknowledged by email.
I still can't log in using either the new or the old password.  I've tried on Edge and Chrome.
Edit: The error message is "Invalid username or password".
DS
Seasoned Champion
Fixes: 22
@ffox
If you're using special characters - "£$%^ etc then this is probably why it's failing.
Plusnet have raised this and it is being worked on - no timescale as to when it will be rectified.
HTH
Fixes: 1,600
@BEST123, we've an acknowledged issue with the change password tool within the member centre, as a workaround for now can you try the forgot password tool Here?
@ffox, can you try the steps DS has suggested letting us know how it goes please?
ffox
No special characters in either password  Any other ideas?
Fixes: 1,600
Thanks for getting back to us.
Can you try clearing cache, cookies and any saved passwords in your web browser then try logging in again?
ffox
Cleared cache, cookies and saved passwords in Edge and switched adblocker off.  No change - still can't log on with old and/or new passwords.
Jubby
All Star
Fixes: 31
Hi @ffox,
I'm sorry to hear that the issue persists.
Are you able to try logging in with another device?
Thank you.
 Lewis G
 Infrastructure Operations Professional
Hi @Jubby, I feel I need to ask this, do you think this issue could be related to this?
SammyM
Fixes: 96
Hello Guys,
Please can you try alternative deviuces and failing that try a password reset without any special characters. If the issue persists after 2 hours of changing the password, please get back to us.
 Sammy M - Sheffield Team
ffox
I have the same problem attempting to log in on an Android tablet.  As I said before, there are no special characters in either of my old or new passwords.
SammyM
Fixes: 96
Hello @ffox,
Can you advise if you have tried the steps outlined by @Jubby? Have you also tried an alternative device?
