Cessation charge?
yumi41
Cessation charge?
Hi
I'm thinking of going over to BT from Plusnet and understand that if I do so while mid-contract, I'll have a fee to pay.  However, what is the cessation charge?  If I wait until my contact is ended with Plusnet, do I really have to pay them £30 to cancel and go to BT?
7 REPLIES 7
Legend
Fixes: 255
Re: Cessation charge?
HI @yumi41The cessation charge no longer applies, and in any case it only applied if you moved to a supplier such as Virgin, who do not use the BT network,
HTH
yumi41
Thank you for the info and the quick response!
Alex
Fixes: 13
Yes I believe it only applies if you wish to cancel broadband completely from your line, so in case you don't want it at all or Virgin where it is carried via a separate link.
In your case moving providers should be fine.
Jonpe
Fixes: 9
@OllieC's post here https://community.plus.net/t5/Broadband/Cessation-charge-quot-active-quot/m-p/1580255#M327511 says that "This charge has been completely removed from our T's & C's."
Mads
Fixes: 79
Hello @all -
Just for confirmation we do not charge the ceassation fee of £30.00 post August of this year. When you leave whether it be to anothe provider on the Openreach network or off (Virgin, Hyperoptic etc) you will just be charged your early termination fees (if you have any) and 14 days notice which will appear on the final invoice.
Hope this clears things up.
Legend
Fixes: 255
Thought that was the case @Mads. I think my post was unclear.Embarrassed
Alex
Fixes: 13
Thanks @Mads
I didn't realise that until just now - thanks for clarifying Smiley
