Card Payments error using Firefox
- My Account/Billing
- Card Payments error using Firefox
Re: Card Payments error using Firefox
16-12-2014 2:42 PM
Quote from: Oldjim Try starting Firefox in safe mode and see if it is the same
Tried - restarting with Addons disabled which seems to be what was called "safemode"
- no joy - still the same
- This is not hugely important - I can use IE on PlusNet payments ................. trouble is it has triggered our curiosity to find an answer
16-12-2014 2:44 PM
16-12-2014 2:50 PM
- I've used lots of drop downs recently on Xmas shopping online - no other problems at all elsewhere
16-12-2014 2:56 PM
- 'January' can be represented by "1" or "01"
. . . - 'September' can be represented by "9" or "09"
If implemented as above, then in future, this will never happen again !
Trying to debug 'kdhuk's particular setup will only solve the problem once, and this problem will soon happen to someone else.
16-12-2014 3:01 PM
16-12-2014 5:22 PM
Do not know if it is relevant...
Your "I cannot reproduce it" screen shot is showing the EXPIRY date drop-downs
The OP's "Here is my view of the problem" is showing the START date drop-downs
Kevin
16-12-2014 5:24 PM
18-12-2014 9:44 PM
19-12-2014 9:55 AM
...........can't seem to change Western Character encoding - tried Unicode but defaults back to Western when viewing the PlusNet Card details page
19-12-2014 11:08 AM
I did wonder about GreaseMonkey but as you've tried with all add-ons disabled it can't be that.
19-12-2014 11:59 AM
For me, the raw HTML look like this (whatever generates the HTML adds a lot of whitespace to it.. ???)
<select id="startMonth" name="cardStartMonth" class="select">
<option value="">mm</option>
<option value="01"
01
</option>
And the DOM matches, indicating it was served as expected and nothing has modified it.
19-12-2014 1:25 PM
see screen shot
Bear with me I'm just about keeping up with the terminology here
In the Frame Source it reads
<option value="1"
1
</option>
19-12-2014 8:45 PM
Ultimately, the reason Firefox is displaying the wrong thing is that it's receiving the wrong thing, which would imply something is intercepting and modifying it.
Another thing to check would be the proxy settings in preferences, advanced, network, settings. usually there's no need for a proxy on a home network, and some malware changes the setting.
Additionally you can investigate what the browser is seeing using the 'Developer Tools' network option, or if you want to get adventurous, you could install wireshark and use it to see what's happening at the network packet level.
19-12-2014 10:20 PM
Check >Regional Options >Customise >Numbers >Display leading zeros
20-12-2014 12:24 AM
