Cannot view my bill online
- My Account/Billing
- Re: Cannot view my bill online
08-11-2020 10:13 PM
I need to access my bills for my accounts and VAT purposes and just get an error message when I go to this section of my account. Please can you fix this, Plusnet?
10-11-2020 7:59 AM
Try opening the webpage in private browsing (incognito mode if you use Chrome)
14-11-2020 9:23 AM
Thanks but this doesn't work - still can't see the bill
14-11-2020 11:50 AM
I think Plusnet have been working on their website as there seem to be several reports of things not working correctly. They did some work this week to remove links to the Help Assistant in the Manage Account page which also borked (intentionally or otherwise) the link in the complaints code to allow a ticket to be raised. They are supposedly working to correct the latter.
On occasion, I have experienced long waiting times to get the log in screen and then to actually connect, and also my referrals breakdown will not load (although the csv file will download!). However, my bills do load. Hopefully Plusnet can sort it out for you.
