Cannot view bill
- My Account/Billing
- Cannot view bill
- « Previous
- 1
- 2
- Next »
Re: Cannot view bill
17-05-2021 6:56 AM
FYI, @broadband_user On my W7 machine Pale Moon works, although it is a little slow to initially load. I can access my bills on it with no issue.
HTH.
17-05-2021 2:32 PM
@jab1 You did mean W7 & Linux? I had no problems with W7 until moving to W10, bill worked for a few weeks last year but not now. Problem generally followed FF updates, or maybe it was w10 updates. TBH I don't bother, just use Edge for a few mins to check bills when necessary.
17-05-2021 2:39 PM - edited 17-05-2021 2:40 PM
@Longliner Yes, I did mean W7 and Linux - wouldn't touch W10 with an extended bargepole. Most likely W10 updates - I've had no issues on the Linux machine in the 8/9 months I've had it, and none on W7, once I discovered and modified the failing 'auto-update' on FF.
- « Previous
- 1
- 2
- Next »
