Cancellation charge
- My Account/Billing
- Re: Cancellation charge
Cancellation charge
13-12-2014 8:45 PM
I'm thinking of leaving Plusnet but was wondering how much they would charge me as I have 7 months left of an 18 month contract.
Is there a formula that they use to calculate a charge?
Message 1 of 8
(1,241 Views)
7 REPLIES 7
13-12-2014 8:46 PM
Look it up here https://portal.plus.net/my.html?s=0&action=account_summary
Message 2 of 8
(696 Views)
13-12-2014 9:08 PM
It says "£86.80 (upon cancellation) " if I'm reading that right.
Thank you
Thank you
Message 3 of 8
(696 Views)
13-12-2014 9:10 PM
If you cancel rather than migrate there will be another £30 to add to that
Message 4 of 8
(696 Views)
13-12-2014 9:18 PM
Skyhunter, If your Account Summary is like mine, the Cancellation charge will be overstated. This is a known issue and there is a Problem open with the PlusNet Developers to fix it.
In the meantime, the recommendation was to insist on a manual calculation of the outstanding charges.
(I will search for Oldjim's linky to the PlusNet info page which details the cancellation charges and update this post if I find it.)
Message 5 of 8
(696 Views)
13-12-2014 9:25 PM
Quote from: Oldjim If you cancel rather than migrate there will be another £30 to add to that
If I migrate to sky does that count?
Message 6 of 8
(696 Views)
13-12-2014 9:25 PM
Quote from: Wheel_nut Skyhunter, If your Account Summary is like mine, the Cancellation charge will be overstated. This is a known issue and there is a Problem open with the PlusNet Developers to fix it.
Thank you
Message 7 of 8
(696 Views)
13-12-2014 9:28 PM
It is actually here http://www.plus.net/info2/legal/price_guide.html and would appear to be - £5.50 + £5.35 = £10.85 per month which means that at present there are 8 months left - it will drop to 7 after the next billing date
Migrating to Sky - you won't be charged it
Message 8 of 8
(696 Views)
