Can't look at renewal offers due to "phone order in progress"
Phantom1874
My contract is due for renewal in January and I recently received an email about renewal offers. When I sign in to my account though there's this message at the top of my account page.
An error has occurred
You cannot make any changes to your account while there is a phone order in progress.
I don't know what the phone order is and I can't see anyway around this message. Any advice? Thanks in advance.
3 REPLIES 3
Fixes: 344
Re: Can't look at renewal offers due to "phone order in progress"
You will need a staff member to sort this - the (supposedly) automatic method of clearing this message on completion of account changes is totally broken - or it could be BT's B2B system at fault. Or you could try ringing customer Support, which may be your best bet.
Fixes: 98
@Phantom1874
If you're looking to continue with a phone service you may need to phone anyway. You can renew "as is" but not upgrade. The phone service will be withdrawn by the end of 2025.
Edit : Try PlusNet Customer Options Team on 0800 013 2632
MikeSt
Hi @Phantom1874. I can see that there are some call features that are currently stuck on your account. I have raised a task for this to be sorted. Please allow 24 hours for this to be actioned. After that, everything should be back as it should be back as it should be.
 Michael Staniforth
