Can't log in
Mart08
Can't log in
Hello
I can't log into my plusnet account it keeps coming up Error please try again later I haven't been able to log in for a few days now. Anyone know what's wrong
8 REPLIES 8
Tibzor
Fixes: 25
Re: Can't log in
Hi @Mart08
Sorry to hear that. I can see that password to account was recently changes as per this notice.
Can you please try to log in by using your username and this new password? Most common reason for problems with logging in is using email address instead of username. If this won't help please try different web browser.
If you are not sure if password is correct, you can change it here
Mart08
Re: Can't log in
Hello thanks for your reply that's the reason I changed my password as it wouldn't let me log in it was coming up Error and it's still doing the same with new password
adamwalker
Fixes: 221
Re: Can't log in
Hi there, have you made sure your entering the right username? This is on emails we send about your account in case you need to check it, do bear in mind that you don't need to enter@plusdsl.net on the end as you would when setting a router up in case that's happened.
I've just tried calling you to but there was no answer so please let me know if there's a good time to get in touch.
 Adam Walker
Mart08
Re: Can't log in
Hello sorry I missed your call I still can't log in to my account everything to log in is correct but it comes up Error try again later I haven't been able to log in to my account for a log time I have changed the password but still the same
adamwalker
Fixes: 221
Re: Can't log in
No worries, let me know if there's a good time to give you a call and I can arrange a work around for you to get it sorted.
 Adam Walker
Mart08
Re: Can't log in
I'm at home now if your free to call
adamwalker
Fixes: 221
Re: Can't log in
Hi there, I won't be able to call today I'm afraid as my shift is ending soon but I'll be able to call tomorrow if that's OK.
 Adam Walker
Mart08
Re: Can't log in
Yea that's no problem chat tomorrow.
