Can't enable static IP
DavePrince
My FTTP has gone live but I can't seem to enable static IP in the 'Add-ons' page.
Current Status :  You are currently using a dynamic IP address
Clicking Activate button does nothing - just returns back to showing the same thing.
I paid the £5 before it all went live.
Any advice? I've reset the router, and my current IP is 80.189.xxx.xxx
Thanks.
3 REPLIES 3
Fixes: 582
Re: Can't enable static IP
@DavePrince the online automated static IP process seems broken on many accounts.
I'm sure one of the Plusnet staff will be along shortly to process it manually.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Account / Billing
MatthewWheeler
Fixes: 503
Hi @DavePrince
That should be sorted for you now
If you reboot your router you'll pick the new IP address up
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
