Broadband
Nisarath
Broadband
My contract will finish on 23April 2025. If I do not renew the contact and wait for couple of months and then shop around any consequences? I am overseas currently hence the question.
Tags (2)
17 REPLIES 17
Fixes: 383
Re: Broadband
@Nisarath Yes - the couple of months and any 'shopping around' time will be charged at the out-of-contract price you can see on your account.
Nisarath
Re: Broadband
Thanks for the reply. If I don't renew the contact and shop around once I get back to the country and go with any provider Plusnet can't charge me?
Fixes: 383
Re: Broadband
As I said - if you do not renew/re-negotiate the contract, you will be charged at the out of contract rate until such time as you do so, or move ISP.
Fixes: 580
Re: Broadband
@Nisarath its not a 'fixed term' contract, its a 'minimum term' contract. Provision of the service doesnt stop at the end of the minimum term!. As @jab1 says , you just move to a rolling monthly contract at the 'out of contract' rate.
Nisarath
Re: Broadband
Thanks for the reply/advice.
Nisarath
Re: Broadband
Thanks MisterW for the advice.
Fixes: 1,495
Re: Broadband
Moderators Note
This topic has been moved from Broadband to My Account / Billing
Nisarath
Re: Broadband
So currently I pay £26.43. and will increase to £58.49 once the contract ends. So if I do not renew I will be on a rolling contract @58.49?
Fixes: 383
Re: Broadband
@Nisarath Correct.
Fixes: 117
Re: Broadband
@Nisarath
I believe it's a 30 day rolling contract you go on. Now you've seen the out of contract price I would suggest you decide on things asap to keep the cost down. Note, if moving, you do not tell PN. You let your new ISP do the work.
If you have a traditional copper based phone line this will be lost if (when) you move. VOIP will be the only way if you want to retain a phone. Note you would also lose PN email and any other add ons you may have.
Bella123
Re: Broadband
I often wondered about what happens if you decided notify the provider to end the service on the contract end date?
If for example like you and travelling for a while.
When you come back is it just as simple of looking for an ISP again, even back to Plusnet as a new customer.
Would you qualify for any gift cards etc
I understand in this case you would loose the pstn phone line though
Fixes: 383
Re: Broadband
@Bella123 If you actually wish to end a contract, then yes, you do notify the provider - the procedure is explained in the 'Legal' link at the foot of every forum page.
Yes - when you come back, you will have to find a 'new' ISP.
If you returned to PN you would not qualify as a 'new' customer until after 12 months of cancelling the contract.
Nisarath
Re: Broadband
Jab1 MisterW John& bmc for replies/advice, very helpful. I guess I will have to go with another ISP or renew with Plusnet. BTW when renewing with current provider does the householder need to be at home as currently iam overseas.
Fixes: 580
Re: Broadband
@Bella123
Yes, but I'm not sure if you'd qualify as a new customer with Plusnet ? ( maybe if there was a significant period before coming back )
If qualified as a new customer then yes.
Correct. If you wanted to retain the number, then it would be possible to port it to a voip supplier in the mean time, even if you didn't use it. For instance porting to A & A would cost £12 and then £1.44/month. You then still retain ownership of the number and In the future you could then port to another supplier when needed.#
edit: maybe if there was a significant period before coming back , as @jab1 says ,  12 months
