Broadband phone package - charged separately by plunet and BT resulting in overcharge
- My Account/Billing
- Re: Broadband phone package - charged separately b...
04-03-2018 6:39 PM
I upgraded my the package online only to find that I had been charged separately by plusnet and BT resulting in overcharging. I had thought there will be only one bill. Has anyone had similar experience? and how can this be resolved?
Re: Broadband phone package - charged separately by plunet and BT resulting in overcharge
04-03-2018 8:07 PM
Who do you pay line rental to?
If you pay it to BT then you will be charged by BT for calls made on the landline.
if you pay line rental to Plus Net then you should pay for phone calls to plus net as well.
Sounds like your line rental is still with BT. Check this out in the Plus Net member centre. If you want to move your phone to Plus Net then don't tell BT, but go to the Plus Net member centre and add the Home Phone package.
06-03-2018 1:12 PM
Cheers for your time on the phone @chinlye
As discussed I'll call you back at about 2:30.
06-03-2018 3:58 PM
Thanks again for your time on the phone @chinlye
I've sent you an e-mail following our conversation.
