Broadband error - no invoice in failed billing
Kennyuk77
I keep getting a message when I log onto some sites, error this account has no invoice in failed billing, it won't go away despite phoning the tech support. Thanks
Fixes: 505
Re: Broadband error - no invoice in failed billing
Hi there.
Sorry to hear you’re seeing this message.
Can you switch your router off for 65 minutes then let us know if you’re able to browse normally after that?
Anoush
Kennyuk77
Tried that still same issue
Fixes: 505
It looks like you've since contacted our support team and this should be resolved now?
