Broadband Usage
- My Account/Billing
- Broadband Usage
- « Previous
- 1
- 2
- Next »
Re: Broadband Usage
09-05-2012 10:15 AM
Re: Broadband Usage
15-06-2012 2:10 PM
I am still unable to view my daily broadband usage although, from what you say, PN have a fix they will be applying. However, I note that Pn are able to show my monthly usage so why on earth is there any problem in showing daily usage? I was able to see daily usage figures until six or so weeks ago.
Re: Broadband Usage
16-06-2012 4:20 PM
Although my monthly broadband usage is still shown my daily usage is still unavailable as it has been for the past six or so weeks. Is ther any likelyhood that this facility will be reinstated in the near future ? I would have assumed that my daily usage, being aggregated to arrive at my monthly usage, was readily available.
Re: Broadband Usage
16-06-2012 5:55 PM
I LOOKED at mine a few moments ago and showed my dailu usage and theb for the week also under summary,,
Re: Broadband Usage
17-06-2012 2:32 AM
Re: Broadband Usage
20-06-2012 9:35 AM
I've just done a bit of maintenance on your account that will hopefully fix the issue, we'll know within in a couple of hours. Unfortunately if it doesn't work it's likely to be part of a wider problem that'll take longer to fix, but we'll see what happens - either way it's an issue we're aware of and we will get it sorted for you. Sorry about this.
Re: Broadband Usage
20-06-2012 9:22 PM
that's approx 1 xbox game, and I've got 4 in the queue with no way of scheduling them for free usage, so they will have to wait i think.
what would be nice is an enhanced allowance, much the same as the adsl guys are currently getting (i'm on the 80/20 fibre trial) which is being discussed elsewhere on these forums. what would be even better is unlimited usage...
Re: Broadband Usage
22-06-2012 12:26 PM
Still no joy regarding my hourly/daily/ weekly Broadband Usage reporting. I first raised the matter under Question I.D 54778466 on 25/04/12. I then received Service notices #s 132916929 and 135227721 saying ''Broadband Usage has been reset'' Recently there was a message from, I think, yourself to the effect that '' Provisioning of your ADSL Account information. ADSL Realm change from plusdsl.net to plus.net. Can you please explain where the problem lies and give me some definite information as to when it will be resolved . Also, what information are the messages on Help Assistant trying to convey.
Regards
Re: Broadband Usage
22-06-2012 2:17 PM
I'll make sure that happens for you and update you with the associated problem ID as soon as I have one.
Re: Broadband Usage
29-06-2012 7:16 PM
still no usage showing, and the extra limit of £5 i set appears to have been ignored as well!
(i was billed £38 odd, which is a tenner more than my bill should be, and a fiver more than the £5 limit i set months ago to ensure i didn't get any terrible bill-shocks)
luckily the complaints dept have said they will waive any extra charges, so it remains to be seen what will actually happen.
ttfn
Re: Broadband Usage
03-07-2012 11:19 AM
Re: Broadband Usage
31-07-2012 1:34 PM
My usage page says I've disconnected or have a new account(!) and isn't showing current month data. Previous months are there but aggregated.
Data is obviously being stored as I've had the limit breach emails.
I'd switch to Extra 60Gb now but it won't be implemented immediately; if I did, when will it apply?.
Re: Broadband Usage
31-07-2012 2:17 PM
It appears you are suffering from the same issue. Any account changes would apply from your next billing date.
Chris
Re: Broadband Usage
04-08-2012 3:53 PM
It's a bit of a pain because I was monitoring useage after starting to listen more to internet radio. The 15Gb limit was breached in July so I wanted to have a look in September before switching to the 60Gb plan.
Guess I'll just have to switch before Aug 15 (billing date) anyway and add additional useage as I go.
(My decision to watch a lot of Olympics internet video doesn't help my monitoring, either! Already 6Gb over 15 with a week to go.)
- « Previous
- 1
- 2
- Next »
