Billing concern
coates2013
Billing concern
I am due my bill on the 13th and tried to check how much it is, I could only go in with the phone bill not in internet? Am I to assume this is an accident on your part and if not, what is going on?
Re: Billing concern
Your broadband bill isn't actually generated until your billing date, though you should be able to get a fair idea of what the charge will be from what you've paid previously? You can see all your billing information on our website here: https://portal.plus.net/my.html?action=view_transactions&s=0
Hope that helps.
coates2013
Re: Billing concern
so somewhere round about the £30 mark?
Re: Billing concern
Well, it'll be just shy of £19 for your broadband and line rental, then there's calls on top of that.
