BT engineer confirmed no internal fault but £65 charge applied.
FIXED- Subscribe to RSS Feed
- My Account/Billing
- Re: BT engineer confirmed no internal fault but £6...
21-09-2020 8:43 PM
Hello.
Looking for some advise on how possibly we could be charged for a call out to fix my broadband after open-reach engineer admitted there has been no internal fault found? The problem was with very slow 0,5 Mbps or less speeds sometimes dropping connection for hours and sometimes working as normal all that lasted couple of weeks and was getting worse and worse.
After a visit engineer tested the connection but could not find any problem. What he did was moving the master socket and checking connection on the pole, luckily that fixed the problem and we had no related problem since. We were aware of £65 fee and we had a chat with engineer that we will not have to pay it. Surprisingly after 2 months we received letter saying that charge will be applied. Anyone experienced similar issue ?
Fixed! Go to the fix.
Re: BT engineer confirmed no internal fault but £65 charge applied.
22-09-2020 8:01 AM - edited 22-09-2020 8:02 AM
@Maggi28 Welcome to the forum.
It would appear that the engineer reported something different and or there has been a screw up. Plusnet will need to see the engineers notes to determine which is the case here.
If a Plusnet staffer does not pick this post up promptly I suggest that you raise a formal complaint, see https://www.plus.net/help/legal/complaints-code-of-practice/
22-09-2020 1:13 PM
When I had something wrong the engineer reported no fault at all, but Plusnet had already acknowledged that there was a fault. The second engineer was spot on and as I thought, the problem was with the street box connection. My sister is now going through the same. Do engineers get a bonus from any callout fee actually charged ?
24-09-2020 8:39 PM
Engineers note
Reason for Charge: Customer Equipment Ticket reference: 203401243 Summary: The engineer that attended has provided us with notes from this visit, they have informed us that the fault you were experiencing was caused by your equipment. The engineer will have either resolved this issue or provided you with advice on how to do so. As this fault has been found on equipment that is not the responsibility of ourselves or Openreach, the engineer call-out charge is applicable.
Openreach engineer bypassed our old 25 years old socket and installed a new one. He said he does it because he is not sure what is causing the problem (problem was intermittent) Both sockets are located in our living room all cabling stayed the same. Is a master socket my equipment ?
24-09-2020 9:35 PM - edited 24-09-2020 9:36 PM
@Maggi28 I would raise a complaint with Plusnet, the master socket is Openreach equipment so the charge is not applicable. I notice the engineer notes said nothing about what equipment was faulty. He/she obviously had no idea what the problem was.
See the Complaints Code of Practice link at the bottom of each page on the forum.
24-09-2020 10:27 PM
Will do so. Thank you for all your help. Will keep you updated.
26-09-2020 7:35 PM
Good evening @Maggi28 I am sorry to hear you've gotten in touch in the form of a complaint, I've emailed you and waiting for your response on the Member Centre to introduce myself. Hope to hear from yourself soon.
06-01-2021 6:25 PM
Plusnet great work, i'm well impressed. Quick investigation and all is sorted, turned out to be engineer error.
Have recommended you to my friends.
06-01-2021 6:57 PM
Hi, @Maggi28!
Thank you so much for getting in touch to let us know. I'm happy to hear everything was sorted quickly for you. I've passed the feedback on for the agent who assisted you. Thank you very much for recommending us! All the best, Ela
