Awaiting new line install and fibre install info, No updates since sign up
- My Account/Billing
- Awaiting new line install and fibre install info, ...
Re: Awaiting new line install and fibre install info, No updates since sign up
26-10-2012 3:38 PM
I can see Chris is dealing with this for you on Twitter and your ticket, I'm sorry about the delays that are going on here. I believe our provisioning team have escalated the order and will update you as soon as they have any more information.
29-10-2012 6:09 PM
Quote from: prettyflyguy Fibre engineer proceeded to install the HG612 modem on the wall next to my current master socket and then tapped into a couple of the spare wires in my current socket. (Is this correct or just cutting corners / cowboying it )
The overthead line to your house carries 2 pairs, so in other words it can carry 2 separate services, so there is nothing wrong with that. I hope he also installed a new NTE5a with a vDSL filter plate for your 2nd (fibre) service. If so, all OR have to do is provision a circuit at the top of the pole, which of course may be easier said than done if there are no spare pairs from the cab!
30-10-2012 8:32 AM
I've just seen ticket reply for my reappointed install. Which is 27/11/2012 67 days after ordering and does not suit either as I can only be in on a Friday.
30-10-2012 9:20 AM
Edit: 2 months to either move a couple of phone only customers onto a DACS to free up a pair, or put in a new cable from Cab to DP is ridiculous.
Edit2: There really must be some incompetent management at OpenRetch to provide Plusnet with an install date without checking of there was actually some available pairs to provide the service. And I hope Plusnet don't even try taking any monthly payment money from your account until the service is provisioned!
30-10-2012 7:46 PM
Regarding the drop wire into my home, none of the engineers bother to take a look in the distribution box pictured here
http://imageshack.us/f/210/020120083041.jpg/
Drop wire in middle and only one of the other cables is being used for my current line the other goes into the wall in spare bedroom and has no nte5 box fitted just the cable end loose. think they assumed it was being used?
Could they not have used this in the first visit? Nobody bothered to look at it when here.
Quote from: Anotherone And I hope Plusnet don't even try taking any monthly payment money from your account until the service is provisioned!
Funnily enough My account is showing everything as complete and activated and that my next bill is due on 26/11/2012.
The day before I am supposed to be (again) connected up
I have mentioned this to CP and he said it wont be collected but I was also told I wouldn't have another 5 week wait for the new install date
01-11-2012 1:26 AM
Quote Drop wire in middle and only one of the other cables is being used for my current line the other goes into the wall in spare bedroom and has no nte5 box fitted just the cable end loose. think they assumed it was being used?
Are you implying that they've installed the modem not in a location that you wanted, did you not say where you wanted it?
It's difficult to see what's going on in that connection box because half of it is in shadow. But if the drop wire is the middle one, it looks as though the right hand one is the one going to your NTE5a's. It looks as though there are jelly crimps connecting all four wires to the drop wire. The LH cable doesn't appear connected and is the one going to the spare bedroom, would that be right?
01-11-2012 10:14 AM
Contacted Chris who said that he was pushing OR for an earlier date and would get back to me Yesterday, maybe he will get back Today with more info?
Yes, I think that is the one going to bedroom.
nte5 and Modem location are where I wanted them in the sitting room, they just didn't use the data extension kit that was part of my order (Which I assume is a better quality cable similar to CAT5e ? ) Just tapped into the current nte5 socket as I said earlier.
But I'm beginning to worry that my fibre speed is going to affected by the wiring that was done on my original nte5 installation that they tapped into instead of installing the new nte5 and running the data extension cable.
Original cabling was ran from back of house up through the loft down to sitting room (which is probably a 15m run) and has around 10-15m of loose wire in the loft.
Could this affect my estimated fttc speed? Some pictures of the original cable run, wiring and close up on connection box below
Does this look up to scratch?
http://imageshack.us/g/684/020120083024.jpg/
02-11-2012 5:03 PM
Sorry for the wait.
03-11-2012 3:50 PM
I received your ticket update yesterday that your pushing for an earlier date, but today on my other open ticket I have received a now later date of 30/11/2012 between 8AM and 1PM from another CSC
I hope that this is just a mix up and an earlier date can be set
05-11-2012 10:52 AM
I hope this date is OK?
Let me know.
05-11-2012 5:15 PM
Grateful for your replies on here also for all your help sorting this problem out and getting an earlier date its very much appreciated
Hoping install goes to plan this time
06-11-2012 2:07 AM
Quote from: prettyflyguy Does this look up to scratch?
I can see all the photos as some are too dark, but those in the loft look extremely unprofessional. The joints should be ok as it's jelly crimped. But you should get the eng to look when he comes, just to check it out. Make sure he doesn't/can't fall through the ceiling
09-11-2012 12:26 PM
Quote those in the loft look extremely unprofessional. ..... But you should get the eng to look when he comes, just to check it out
I Should have said, the last engineer tidied up the wiring and put a( BT80? ) junction box between drop wire cable in the loft and the cw1308 cable and stapled/crushed the cable to the joists up there. Just hope he hasn't damaged any wires in the cable. pics below.
http://i47.tinypic.com/14tt4jl.jpg
http://i50.tinypic.com/1hf3m0.jpg
http://i46.tinypic.com/2ch834.jpg
http://i50.tinypic.com/30u31c7.jpg
Regarding the cw1308 run from loft are FTTC.
Are installs from what I've researched not meant to be from where the drop wire comes into the house, NTE5 installed directly on that inner wall near power outlet for modem. Then from there run the cat5e Data extension cable where EU requires it?
I assume that they use cat5e from near enough where drop wire comes in for a reason and not cw1308 which is what mines is from drop wire Get the feeling my speeds may be affected with the cw1308 and might be more prone to interference on the line with it instead of the cat5e
Anyway, Install meant to be Today, been up since 7, Engineer booked for between 8am and 1pm. 12:20 now and still waiting,
If any PN staff read this could they check that its still on for Today please and let me know so that I'm not wasting another day off ?
09-11-2012 1:44 PM
09-11-2012 4:21 PM
